Ambient air temp sensor location?
Old Nov 19, 2012 | 04:04 AM
mopar204's Avatar
mopar204
Default Ambient air temp sensor location?
I've had my check engine light since i've owned my truck for an ambient air temp sensor and i was just curious where its located so i can change it and turn that engine light off for good oh and finally be able to use command start
Old Nov 19, 2012 | 04:34 AM
erau's Avatar
erau
At the red arrow.
Old Nov 19, 2012 | 03:14 PM
marcsnyder05's Avatar
marcsnyder05
Old Nov 19, 2012 | 05:13 PM
Reject's Avatar
Reject
So your telling me I made a very fancy Aluminum Bracket to hold that, when my truck doesnt even use it haha. I figured it had something todo with the airbags. I didnt drill a hole to bolt it back on when I did my custom rad support.
Old Nov 19, 2012 | 09:11 PM
From what I hear, if you unplug it, your ac work start blowing really, really cold air...but the CEL does come on.
Old Nov 10, 2013 | 05:55 PM
Shannonk507's Avatar
Shannonk507
Default Dodge 2012 Journey
I have a 2012 Journey where this is the problem. I can probably take it in next week to get it fixed. If that is the case, could it lead to further problems until then? It currently reads -40 for the temp. Thank you.
Old Nov 10, 2013 | 06:38 PM
Welcome to DF! If it is your ambient temp sensor only it should not cause any driveability issues. You might post this in the Journey section as this discussion pertains to Dodge Dakotas, though I'm sure these outdoor air temp systems may be the same.
Old Nov 10, 2013 | 09:34 PM
mega cab ram's Avatar
mega cab ram
What does CEL stand for?
Old Nov 10, 2013 | 10:04 PM
dakotaff's Avatar
dakotaff
Check Engine Light.
Old Nov 11, 2013 | 10:26 AM
mega cab ram
Thanks
