High flow cat for a 3.7 : yay or nay?
Old Nov 29, 2012 | 06:16 PM
Ronius_MAXimus's Avatar
Ronius_MAXimus
Default High flow cat for a 3.7 : yay or nay?
Hi, im wondering if it would be of any benefit to replace the oem cats on my 07 dakota v6 with high flow cats? Im looking at the spintechs in particular, but would certainly entertain something cheaper as well. Do any of you think they are worth the investment or is oem good enough? Im a noob here and would like some opinions... Any other solid brands? Did it help your mpg or make your car louder? Thanks in advance.
Old Nov 29, 2012 | 06:47 PM
DaKoCuN's Avatar
DaKoCuN
I think the restriction in the Dakota's exhaust sistem is the y-pipe if you could replace that and add a Programmer, the high flow cat would be worth it.
Old Nov 29, 2012 | 07:37 PM
Ronius_MAXimus
I havent take A look underneath but what is the best way to correct it? Just run 1 cat converter? Will i get check engine lights?
Old Nov 29, 2012 | 09:10 PM
JimBio's Avatar
JimBio
Nay. Not enough gain for the $.
Old Nov 30, 2012 | 07:10 AM
Blown287's Avatar
Blown287
I had spintech highflow cats on mine and they were a huge improvement. With that being said, I was running 14psi of boost, lol. For stock or minimal modding I would say no. If you plan on cams, boost, nitrous, etc. then I would say yes.
