Posessed blinkers
Old Dec 7, 2012 | 08:52 AM
northgator8's Avatar
northgator8
Originally Posted by clayh
Our 2008 started doing that. IT was the multifunction switch. I got a replacment from NAPA, around $70 CDN?
The steering wheel does need to come off. Its easy though, just undo the nut(but leave it on a few threads) then yank on the wheel. Leaving the the nut on a bit keeps the wheel from smacking you in the chest when it pops loose.
There are 2 yellow caged fuses in the the underhood fuse box that should be pulled to disable the airbag.
Search is your friend:
https://dodgeforum.com/forum/3rd-gen...8-writeup.html
Thanks for that - problem returned last night for a bit - guess I am buying less beer this weekend!
