HELP Dodge DAKOTA seatbelt NOT REGISTERING
Hey all
as of yesterday i dont know what happened, a wire must of gotten cut
but my seat belt is not registering being fastened in.
even when buckled it continues to chime and says it is not buckled up.
very annoying.
i dont know if trying to disaBLE the chime will work, i read about it but i dont think it will where it wont even register that it is buckled at all..
please help.....bring to dealer? try disconnecting the battery?? thanks for any help!
Alex
very annoying.
Alex
Damaged wire, or dirty connection.. Could be one or the other.
Locate the plug under the seat. It hangs down a touch so it's not impossible for something to have caught the wires. Check the wires. if damaged, repair. If they look to be in one piece, try disconnecting and reconnecting the plug. (Could just be dirt/corrosion in the connection).
I ended up just making it permanently think it's clicked in, much easier and don't ever hear the dinging. I am however a very avid seat belt wearer and won't usually start the truck without it on.
I also have totalled 2 mustangs, 1 motorcycle, and been in 4 other fairly serious accidents.
I can tell you right now, whether your fault or not, the belt saves you, NOT the airbags in 90% of the cases. I wouldn't go anywhere without it.
Just ranting for anyone that may read this!!!
**** so i just found a disconnected wire right at the buckle.. a black wire is disconnected...and there is not room for play to try an connect them back together..and i have no idea how to take apart the buckle....****
There are two wires going to the connector. Cut the wires off the connector so you have enough slack to pull them out from under the seat. Strip the ends and wire nut/buttsplice or solder the wires together. This will permanently turn the seat belt light out. I did the same, but like blu3p0ny, I don't go anywhere without my seatbelt so I don't need a stupid idiot light to tell me I need to fasten my seatbelt.
it was right at the bottom of the buckle. no wire to play with
i was lucky enough to get someone to hold the wires touching together while i could disable the chime! phew that wasnt easy, got it done though! thanks all
