2005 Dak 4.7 lliter Misfire Cylinder 3
My water pump let loose on Highway. Pulled over right away but temp did jump high. Pump blew at the pulley shaft and everything I mean everything got wet.
I replaced the pump flushed the system and added new antifreeze - oil change due the the temp. Ran truck to flush/ check new and oil change for leaks and what not. No engine light while at idle must have run at least 30 - 40 minutes for flush and fillup of Antifreeze.
Went for test drive and on drive got the Check Engine light, code read Misfire Cylinder 3 - Coil was wet on outside as could be expected pulled coil and dry inside, pulled plug and it looked ok but worn as I expected. Changed the plug and still getting random misfires during acceleration.
Any Ideas?
Any Ideas?
