Transmission Issue
Old Dec 31, 2012 | 06:21 PM
Narsys's Avatar
Narsys
Default Transmission Issue
mine started lipping TODAY... just driving 50ish on a country road to pick a boy up with his buck... as I slowed _ something clunked.... my truck is a 2007 V-8 Magnum 4wd... 110,xxx miles .... never abused ... it will always smoke tires on pavement... now this evening 1st is fine 2nd spins truck side ways like nothing .... D it just eases forward .... fro 400 to 2000 rpm and then "seems Normal" fluid is where it shold be ...ANY IDEAS ?
Old Jan 1, 2013 | 02:03 AM
Paulinations's Avatar
Paulinations
well thats a contradiction! haha!
Old Jan 1, 2013 | 02:10 AM
jasonw's Avatar
jasonw
Site Moderator
Moved this to its own thread, since the other was very old and not exactly the same issue you have here.
Get it checked out by a pro-mechanic that you trust. Could be something simple, you never know. These transmissions aren't the same as the old 42RH/RE and 46RH/RE used in the older Dakotas and Rams, they aren't nearly as temperamental or unpredictable, and are generally more reliable.
Old Jan 2, 2013 | 09:16 AM
Narsys's Avatar
Narsys
thanx ...
I did NOT say I went around smoken tires all the time .... I said it WOULD .... now it wont even spin tires on the GRAVEL road I live on...
Old Jan 2, 2013 | 09:30 PM
thecause17's Avatar
thecause17
I'm a firm believer in keeping fluids changed in Chrysler vehicles, abused or not. If you're at 110k miles and it's never had a fluid/filter change, you're long overdue. I did my first one in my truck at 60k.
Old Jan 3, 2013 | 12:59 AM
Paulinations
thanx ...
I know I was just joking around!
