Receiving 2005 as a gift
Old Jan 25, 2013 | 03:45 PM
adamjeeps's Avatar
adamjeeps
Here is the build sheet graciously provided by Dodgecares. Anything good or bad I need to know?
Vehicle Description
DODGE DAKOTA P/U CLUB CAB SLT 4X4
Model Year
2005
Body Model
ND 5 H 33
Color
PW7- Bright White Clear Coat
ISD
01/25/2005
Engine
EVA- 4.7L V8 MPI Engine
Transmission
DGQ- 5-Spd Automatic 545RFE Transmission
P9
Cloth 40/20/40 Split Bench Seat
-J3
Khaki
AJKS
Convenience Group
AJPS
Power Convenience Group
APAS
Monotone Paint
A82P
4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
BAZS
136 Amp Alternator
BCES
600 Amp Maintenance Free Battery
BCSS
Battery Run Down Protection
BGJS
Pwr Disc/Drum Rr Anti-Lock Brakes
CBEP
CBZS
Prem Vinyl Door Trim w/Map Pocket
CFRS
Rear 40/40 Folding Split Seat
CGZS
Passenger Air Bag On/Off Switch
CG3S
Advanced Multistage Front Air Bags**
CKES
Front Seat Area Carpet
CLAS
Front Floor Mats
CSRS
Passenger Assist Handles
CSWS
Driver Assist Handle
CUZP
Center Armrest Storage
DGES
All 5-Speed Automatic Transmissions
DGQ
DHAP
Lock-Up Torque Converter
DHTS
Elec,Shift-on-the-Fly,P/Time T/Case
DJDS
205MM Front Axle
DMDS
3.55 Rear Axle Ratio
DRBP
Corporate 9.25 LD Rear Axle
EVA
4.7L V8 MPI Engine
GACS
Tinted Glass Windows
GBBS
Tinted Windshield Glass
GCBS
Front Door Tinted Glass
GEGS
Deep Tint Sunscreen Glass
GFD
Rear Sliding Window
GNAS
Rear View Day/Night Mirror
GNDS
Driver Side Sun Visor
GNES
Passenger Side Sun Visor w/Mirror
GURS
Power Mirrors
GXRP
Keyless Entry
HAAS
Air Conditioning
I25S
Route 25 - NS, Winston-Salem, NC
JAAS
Instrument Panel
JA2S
Instrument Cluster w/Tach
JCBS
120 MPH Primary Speedometer
JHAS
Var Intermittent Windshield Wipers
JJBS
Dual Note Electric Horns
JJJS
12V Auxiliary Power Outlet
JPBP
Power Locks
JPDP
Power Windows, Driver One-Touch
KRXS
STRIPE/BADGE/MOLDING/COLOR
K1XP
K17
Do Not Use
K8WS
LACS
Illuminated Entry
LAFS
Key in Ign/Seat Belt Warning Buzzer
LAJS
Headlamps On Warning Chimes
LALS
Low Washer Fluid Warning Signal
LAMS
Door Ajar Warning Lamp
LCDS
Map/Dome Reading Lamps
LCHS
Rear Dome Lamp
LMBS
Halogen Headlamps
LNJS
Fog Lamps
LPES
Cargo Lamp
LPSS
CHMSL Lamp
MBES
Bright Rear Bumper
MB4S
Dark Gray/Bright Front Fascia
MFDS
Bright Grille
MGAS
Ram's Head Badge
MHAS
Black Windshield Moldings
MUMS
Dakota Badge
MUZS
SLT Badge
NAS
50 State Emissions
NBKS
EVAP Control System
NBQP
Federal Tier 2, Bin 10A Emissions
NFBS
22 Gallon Fuel Tank
NHMP
Speed Control
NZDS
Next Generation Engine Controller
PW7
QW7S
RCDS
4 Speakers
RDDS
Fixed Long Mast Antenna
REFS
AM/FM Compact Disc Radio
SBAS
Power Rack and Pinion Steering
SCDS
Luxury Steering Wheel
SDBS
Heavy Duty Suspension
SFBS
Front Heavy Duty Shock Absorbers
SGBS
Rear Heavy Duty Shock Absorbers
SHCS
Front and Rear Stabilizer Bars
SUAP
Tilt Steering Column
TBBS
Full Size Spare Tire
TBMS
Tire Carrier Winch
TXV
P265/70R16 OWL All Terrain Tires
TZAP
Goodyear Brand Tires
WDQP
16" Steel Spare Wheel
WD1S
16X8.0 Cast Aluminum Wheels
XBSS
Pickup Box
XCAS
Occupant Classification System
XDXS
Scissor Type Jack
XSLS
Brake/Park Interlock
YAAS
Build To U.S. Mkt. Specifications
YEP
Manuf Statement of Origin
YGSA
3 Additional Gallons of Gas
ZAVP
Spring - Left Rear
ZCFP
Spring - Left Front
ZNVP
Spring - Right Rear
ZRFP
Spring - Right Front
Old Jan 25, 2013 | 06:36 PM
Pretty standard issue.
Old Jan 26, 2013 | 10:54 AM
superdak05's Avatar
superdak05
the corpoate rear is awesome, it's dodges way of saying posi traction, love my 05 and it still runs strong at 135000
Old Jan 26, 2013 | 03:12 PM
jasonw's Avatar
jasonw
Site Moderator
Thats a negative there, sir. Everyone has the Corporate rear axle, whether it be 8.25 (V6) or 9.25 (V8) sized. The "LD" in that line doesn't stand for Limited Slip Differential, it stands for Light Duty.
The build sheet will specifically list a limited slip differential if the truck came with one.
Old Jan 26, 2013 | 03:40 PM
dakotaff's Avatar
dakotaff
This is what you want to see on the build sheet:
DSA Anti-Spin Differential Rear Axle
Old Jan 26, 2013 | 03:59 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
I wish mine had one..still considering an Auburn
Old Jan 28, 2013 | 09:26 AM
northgator8's Avatar
northgator8
That is what I see in my build sheet! No wonder I cant have much fun in the snow . . .
