whining/humming
Old Feb 16, 2013 | 10:51 AM
  #41
whitecotton03's Avatar
whitecotton03
2nd owner. previous owner was an old man. truck has 74k miles. never been to huge of a dodge fan and i guess i had bad luck with my first. always was and will be a ford guy. next vehicle f150
Old Feb 16, 2013 | 11:07 AM
  #42
There do seem to be a few Monday trucks in this mix. Probably seems like a higher percentage than other manufacturers, but IMO, since production numbers are low, it just seems like more. Hope everything turns out the best for you no matter what you decide to do.
Old Feb 16, 2013 | 11:57 AM
  #43
whitecotton03
I tried giving dodge a try and unfortunately it didnt work. Cant say i didnt try. But thanks
Old Feb 18, 2013 | 10:27 AM
  #44
northgator8's Avatar
northgator8
Only Whine/Hum I ever heard with my vehicles was the ex-girlfriend. Solved that problem - cost of Maintenance went way down too!
If you drop a whole line of vehicles from you list because of one problem with one truck, you might run out of makes pretty quickly. They all have problems and if you are unlucky enough to end up with that one, it's going to be a pretty short list pretty quickly. Buying used often puts you into the pool of problem vehicles because there is often a reason that someone trades/sells.
Old Feb 22, 2013 | 07:21 PM
  #45
baross1's Avatar
baross1
Don't know if you found your problem yet,but I agree with DakoCun on the wheel bearing. Just had alot of front end work done on my 06, and the noise I thought was whining/humming from the tires was a bad bearing/hub. Noise gone now. Good luck
