ding-dang idiot lights !
Old Feb 10, 2013 | 01:12 AM
Frankiejaime88's Avatar
Frankiejaime88
Take it to the dealership so they can recalibrate the sensors in the seats
Old Feb 10, 2013 | 01:15 AM
Frankiejaime88
It happened to me when I took my seats off to run wires for my amp
Old Feb 10, 2013 | 10:18 AM
gannan's Avatar
gannan
I am so thankful for all your responses, and I am working through the list of things I can do... dealer will be the last option.
Understanding that this is a common problem, does anyone know if there have been any recalls for this ?
Old Feb 10, 2013 | 10:33 AM
I don't think it is a common problem. I never had issues with mine. I think it mostly happens when you mess around with the passenger seat, it somehow screws with the load cell calibration.
Old Feb 10, 2013 | 09:49 PM
Frankiejaime88
I think it was like the second or third time I took my passenger seat out, I doubt a recall will happen because how many people take the seats out. The airbag will still work if needed.
Old Feb 10, 2013 | 10:02 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
The only issues I really ever see with Dakotas is a bad connection on one of the seat belt switches or a belt pretensioner. A couple with airbag ON/OFF switch faults too. They are few and far between though. There should be 3 fuses 9 (10A), 46 (10A) and 57 (20A) in the IPM. That's the fuse box with the shiny front control module attached to it with 4 screws.
The answer to your OBD questions....
ALL of the modules are connected to and communicate with each other on the BUS....But, you won't ever see a code related to any of them in the PCM unless there is a communication fault and the PCM can't get BUS signals from one of them. You will need a shop with an expensive aftermarket scan tool that does more than Powertrain, or the one that the dealer has.
Old Feb 11, 2013 | 07:50 AM
gannan's Avatar
gannan
Again Guys and Gals thanks for many replies... several votes for the seat load sensor, & belt annd fuse circuits etc. I shall get busy looking [ and hope I don't pop an airbag in the process ]
Old Jul 11, 2013 | 10:00 AM
gannan's Avatar
gannan
Thank you TNtech for this input -- it is more than I have been able wring out of my local dodge garage...Sorry it took so dang long to respond to you, just been busier that a one-armed paperhanger w/ an itch...
Is it just me, or is anyone else not impressed with Chryslers' move to associate with FEEYAT ...
Old Jul 12, 2013 | 09:59 AM
TNtech's Avatar
TNtech
Better than Daimler or Cerberus...Don't misunderstand things as being all Fiat though. The post-bankrupsty era is a different world in our circles. It wasn't really a "move". The Feds basically gave Chrysler to Italy and loaned them billions to resurrect it. Fiat is doing a good job with it so far. GM on the other hand....
