drivetrain??
Old Feb 13, 2013 | 10:34 AM
Neil Hall's Avatar
Neil Hall
Default drivetrain??
I got a 05 dakota slt 4x4. Im curious if the truck has a lsd in it or an open diff? Also what is the difference between the two 4x4 settings? One just being low range?
Old Feb 13, 2013 | 10:51 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
If you have your vin you can get the build sheet for it. Just Message Dodgecares and ask. There is also a website you can go to as well and plug your VIN in but thats a bit slower These would be the easiest. You can also find out manually by jack the rear axle up.
The settings are like you said. Check out your OM for the specific definitions. If you dont have one I can email you a copy of the 2007 which is practically the same minus some options.
Old Feb 13, 2013 | 11:58 AM
If you want a quick answer to your limited slip question, jack the truck up by the rear pumpkin, put it in neutral (engine not running), parking brake off, and spin one wheel. If the other wheel spins in the same direction, you have limited slip, if it spins in the opposite direction, you have an open diff.
Old Feb 13, 2013 | 01:02 PM
lghtngblt02
Yep that's a quick and dirty way
Old Feb 13, 2013 | 01:06 PM
Neil Hall's Avatar
Neil Hall
Yeah i know the jack trick. Just that its winter and its dirty under there. Lol
Old Feb 13, 2013 | 01:07 PM
DodgeCares's Avatar
DodgeCares
PM me the vin and I will get you the info.
Old Feb 13, 2013 | 02:10 PM
There you go ^^^
Old Feb 17, 2013 | 11:49 AM
superdak05's Avatar
superdak05
open up your glove box and on the back of it there should be a sticker stating info, mine says corporate rear with 3.55 gears, which now have been changed to 4.10 gears, also you can go to www.allpar.com and type in your vin for info on your truck
