Lots of clicking but motor won't turn over
Old Mar 3, 2013 | 06:44 PM
DakotaAgain?'s Avatar
DakotaAgain?
Default Lots of clicking but motor won't turn over
It happened all so suddenly. Pulled in the drive way but when wanted to start it again I just heard clicking but no turn over. The speedo and tach needles swing back and forth while click is goes on. Cleaned both terminals to a shine with a wire brush then tried to jump it with another car but got the same clicking and no turn over. Lights do come on and do not dim when I engage the starter.
Old Mar 3, 2013 | 06:54 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
remove the belt and check for any seized pulleys. do not keep trying to crank it or you may ruin the starter motor
Old Mar 3, 2013 | 07:37 PM
DakotaAgain?
Seized pulley? Does that come before of the starter?
Old Mar 3, 2013 | 08:41 PM
erau's Avatar
erau
Sounds like your battery is on its last leg but still has just enough power to run the lights, but can no longer hold enough of a charge to engage the starter/solenoid. Your last start with it appears to be just that.
If it were me, I would try a new battery.
(You'll find many prior posts describing the weird things that happen when the battery is going dead. Yours doesn't fall out of that realm.)
Old Mar 3, 2013 | 08:49 PM
norma jean's Avatar
norma jean
when my battery died, all the lights worked, we tried jumping it with another car, didn't work, there's a point where a battery cant be charged with another car, AAA came checked everything and told me the battery died
Old Mar 3, 2013 | 09:44 PM
wingman_214's Avatar
wingman_214
Its your battery.
A bad battery has good voltage but has low amperage. That's why low amp accessories like the lights and radio work, but high load starter only click s and what not.
Voltage is like gas in the tank, amperage is how much horse power the engine has.
Old Mar 3, 2013 | 09:56 PM
DakotaAgain?
I have jumped it 3 ways
1. An older battery that was out of another car and was under trickle charge. I am sure it had full charge.
2. A brand new Die Hard battery that I just bought. Used it to jump but didn't actually put it in.
3. Another car running.
Is it still the battery?
Old Mar 3, 2013 | 10:15 PM
wingman_214
Are the battery terminals clean and tight? Corroded or loose battery terminals can cause the same issues.
You may want to try gently massaging the starter motor with a hammer. The carbon brushes could be worn out or possibly the commutator.
Old Mar 3, 2013 | 10:30 PM
mulie4x4's Avatar
mulie4x4
Yes it is the battery, you must take the old one out and put the new one in. Jumping a non-functioning battery well not work, not sure why but it wont.
Old Mar 3, 2013 | 10:46 PM
DakotaAgain?
I too tend to suspect the terminals. I connected a battery charger to the battery that is in the car but the needle did not move at all which tells me there is a bad connection somewhere. What baffles me is that I cleaned them pretty good. Where else do they make contact.?
