OEM Skid Paperplates
Old Mar 13, 2013 | 06:30 PM
Goat437's Avatar
Goat437
Default OEM Skid Paperplates
I just got the OEM skid plates and I'm a little disappointed. They don't seem too armored... Anyone with them installed think I could fit like 1/4'' Steel plate over them installed? or maybe some steel rod reinforcing? I don't want to sacrifice anymore ground clearance then I have to.
Also I know they need to be able to take a hit because I already dented my gas tank and punched the side shielding off..
Old Mar 13, 2013 | 11:27 PM
Reject's Avatar
Reject
I have a nice mark in my gas tank, and I only have a 2wd lol
Ive stayed away from OEM because of rusting issues where I live. I know someone else just added them to thier truck not to long ago
Old Mar 14, 2013 | 12:35 AM
dimesismoneytoo's Avatar
dimesismoneytoo
I have the OEM skid plates and have never had a problem with them. I've high centered on sand to rock to wood and everything is just fine and dandy. I've slammed on to stuff before and no damage. If the 1/4" steel they made it with isn't sturdy enough for you, maybe make one with 1/2" steel, that'll stop anything you throw at it. On them lacking armor, they're skid plates, meant to protect from bottoming out on things not protect the sides of your gas tank and transfer case from debris.
Old Mar 14, 2013 | 08:41 AM
dakotaff's Avatar
dakotaff
I just put the OEM skid plates on, and you might be able to add to the transfer case skid plate with some longer bolts. I really don't see an easy way to add to the fuel tank skid plate, and I thought that they were pretty good protection already. The fuel tank skid plate weighs 30 pounds alone.
Old Mar 14, 2013 | 03:35 PM
Goat437's Avatar
Goat437
Fair enough. I'm definitely glad to have something there, was just hoping for a bit more I suppose, I'll take a picture later of the impact I'm talking about to the gas tank.
Old Sep 10, 2013 | 03:23 AM
BigHornToad's Avatar
BigHornToad
I got a question about the gas skid mounting! Just bought one for my 2WD and bolting up the passenger side looks easy. The driver's front I need a bolt but my question is the driver rear - there's nothing there on the frame but a big hole (I believe that's where it lines up at). Is there some special mount I have to buy? Can anyone take a quick pic for me, I'd really really really appreciate it!
