o7dakQC gettin shocks-then struts - first wanna try an fix a squeek
Old Mar 26, 2013 | 09:01 AM
  #21
northgator8's Avatar
northgator8
Originally Posted by calixdakota
whatever i did not know I was going to get flamed.
And yet, you set yourself up again!
How is the above to be read?
Whatever I did not know, I was going to get flamed!
Whatever! I did not know I was going to get flamed!
Whatever I did, not know I was going to get flamed.
Sadly, if you are that thin-skinned, you shouldn't get under the truck to change your shocks, you will bleed to death!
And yes, many are like that. We have fun and help out.
Last edited by northgator8; Mar 26, 2013 at 09:02 AM. Reason: Removed a flamethrower
Old Mar 26, 2013 | 09:11 AM
  #22
donkeypunch's Avatar
donkeypunch
King Jackass
I said directly - i know there are other posts with this question - but i wanted to ask it - hoping that others who had posted the same question - and received valuable and pertinent information to the post - that was successful in solving there problem COULD REPLY.
NO NEED FOR assault and battery.
**** man
If you thought that was assault and battery, then I would suggest a re-evaluation of your resistance to melting at the same rate as ice.
Look, we all do have quite a bit of fun on this forum. However, you still haven't answered my question or attempted to see where we are coming from. You asked a question and then got an answer you didn't want. If you are going to be upset at the other members responses, then I'm not really sure that a forum is the right tool for you.
Please understand that we all are willing to help and answer any questions that you have. Adversely, please understand that when you ask a question and then stomp the solution into the ground, we might be inclined to stop you from going any further.
Now, before this turns into a whirl-wind of f*ckery, lets get back on topic.
Can you please provide us with the information on your truck:
-what did you have replaced in the front end?
-what brand of parts did you use?
-who did the work?
