2008 Dakota Electrical Issue
Old Apr 16, 2013 | 11:02 PM
gegentry04's Avatar
gegentry04
Yes, once the key was allowed to roll back to ON it would still be engaged.
I tested the voltage across the battery terminals now that the new alternator was installed and noticed only 12.7 volts, but if I stuck the leads to the battery cables themselves I would get fluctuations of 13.8 down to 12.6, so I replaced the battery terminal ends, even though I had replaced them only months ago, and have now gotten a steady 13.8 across the battery terminals and all problems appear to be corrected at this time. Hopefully this continues. Thank you for all the help.
Garrett
Old Apr 17, 2013 | 12:14 AM
Reject's Avatar
Reject
I covered my Battery terminals in Die-Electric Grease to help keep them from corroding and keep a good connection.
Even when one of my terminals came very loose (I was able to just pull up and it came off) the grease still kept a good enough circuit to start without issue.
I only found out it was loose when I tried to boost my brothers car.
Old Apr 17, 2013 | 01:01 AM
gegentry04's Avatar
gegentry04
Yea, I got some kind of pink/red spray paint type terminal protectorate and coated liberally.
Old Apr 17, 2013 | 07:27 AM
Alfons's Avatar
Alfons
I find that the paint type coatings don't last very long although they look good. Di-electric grease or even general purpose grease work well, last, and are easy to replace when they rub off.
Old Apr 21, 2013 | 10:24 PM
gegentry04's Avatar
gegentry04
Yea, I agree the grease works better. The spray stuff came in a package with terminal cleaner. Anyhow, everything has been on the up and up since.
