Problem with brakes
Old Apr 18, 2013 | 11:47 PM
dakblack08's Avatar
dakblack08
Default Problem with brakes
I have a 2008 4x4 slt. I recently had a leveling kit, tires, and rims installed. My problem has been with the brakes. This problem occurred before everything was installed. When I go to stop, if I brake hard the noise doesn't occur but when I brake softly there is a noise that is definitely noticeable and it happens every 360 degrees. Obviously it is a problem with the brakes but I don't know what and I don't know what to do about it. I would appreciate any help from fellow members. Thanks!
Old Apr 19, 2013 | 07:24 AM
Front or rear? Left side, right side? Is it accompanied by any brake pedal pulsation? When was the last time the brakes were inspected/serviced? Have you done anything on your own to diagnose the problem? Kinda hard to tell you anything definitive with just "I got a noise from my brakes, what is it?" type of question. You are aware brake pads have wear indicators that make noise when the pads are worn down to a point that requires replacement, right? I would suggest doing some investigation yourself sincethe truck is with you. You could start with the afformentioned inspection. Maybe a tire rotation to see if it moves to a different area. Kinda hard to tell you anything though with the lack of pertinent info.
