Stock
Old Apr 25, 2013 | 12:44 PM
viper359's Avatar
viper359
Default Stock
Can I get a confirmation from you guys;
My 2006 Dak Quad Cab 4wd SLT is running 245/70/16 I can switch to 265/70/16 just fine, on the same rims, with no additional work required right? Basically, I can buy them and toss them on as if they were the 245/70/16? I am going to toss some General Grabber AT/2 on.
Old Apr 25, 2013 | 12:49 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Yes you can. This is the stock tire size for the SLT models. 245/70/16 is what came on the STs.
Are they the stock steel wheels or stock alloys?
Old Apr 25, 2013 | 01:14 PM
viper359's Avatar
viper359
according to my build sheet, the following:
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TVFS P245/70R16 BSW On/Off Road Tires
TZAP Goodyear Brand Tires
WDQP 16" Steel Spare Wheel
WD1S 16X8.0 Cast Aluminum Wheels
Old Apr 25, 2013 | 02:27 PM
Almost 1" wider and just at 1" taller. You should be fine. You could also read this and get some good info.
https://dodgeforum.com/forum/3rd-gen...ire-setup.html
Old Apr 25, 2013 | 03:05 PM
viper359's Avatar
viper359
Thanks! Reason I ask is because the General Grabber AT/2 have the peak snow rating on these size, but not the stock size that came for my truck. Most of the time I am farting around the city, so no big deal, but a few times a season, I am up in northern Ontario, and that extra little bit just makes the drive easier.
Old Apr 25, 2013 | 03:32 PM
donkeypunch
King Jackass
If you are eventually planning on doing a leveling kit, do a 265/75/16 tire size. Here is a picture of when I had that size tire on a 2" leveling kit.
Old Apr 25, 2013 | 04:47 PM
dakotaff's Avatar
dakotaff
265/70/16 will fit on the 16x8 alloys perfectly, nothing whatsoever to worry about.
FYI, your speedometer will be a little off due to the larger tire height. It will not hurt the truck at all.
Old Apr 26, 2013 | 11:18 AM
kjpark's Avatar
kjpark
i have an 06 quad slt as well. Stock i had the 17" option so i started with 265/70-17 which is 1" (31.6 vs 30.6) more than what your getting and it was fine. So you'll definitely be good to go with those. And yes Dakotaff is correct, my speedo is off about 1.8mph so your should be around there if im not mistaken
Old Apr 26, 2013 | 03:18 PM
viper359's Avatar
viper359
I have been looking at the BF Goodrich All-Terrain T/AŽ KO, but it says its LT tire. So for my tire size, 245/70/16, it says LT. Will a light truck tire fit just as fine as the stock passenger 245 as stated by Dodge? When I goto the BF Goodrich website, put in my truck info, it doesn't even offer up these tires.
Old Apr 26, 2013 | 04:03 PM
A P245/70-16 is the same size as an LT245/70-16, otherwise they would be a different size if they were a diffwerent size. It's a difference of load rating.
