Another Towing Question-Raider V6
I need some advice and opinions. I have an 07 Mits. Raider-V6-2wd. I need to tow an 1983 chevy pickup 4x4 one-way 1000 miles. My question is does the V6 model and V8 models have the same transmission? Also, my truck is equipped with a transmission cooler, however, its tied into the radiator. I plan to put an external coil for the cooler. Is this possible and how easy? Also, how hard would it be to put a trans temp gauge in? TIA
If you have the automatic, no, the V6 and V8 models do not have the same transmission. The V6 came with a 42RLE auto and the V8 with the 545RFE auto.
If manual transmission (not sure that was offered for the Mitsu?), then yes, they are the same.
You could buy something like an Ultragauge so you can monitor transmission and engine temps as an extra precaution.
The transmission cooler should help if installed properly, but there's other factors to consider such as brakes, tires, diff, etc.
However, for a longer distance (especially highway), you will need something with more capability.
