Did you use the swaybar bushing mounts fore the skidplate? That's genius.
Cody's bumper is built that way as well.
Neil, your bumpers look awesome! I definitely like your designs. Mine are still in the "fabbing" process. I love your black on red swagger....it looks so good!
I'm looking too do something simple with the exhaust.. any ideas? should I bring it straight back from the y-pipe through a magnaflow then dump it before the rear tire?
also i was planning on using these too replace my wiper fluid and coolant catch tanks. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180977836437&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
I'm open too suggestions and whatnot!!! thanks.
anyone got any ideas about where i can move the coolant overflow tank/wiperfluid tank too?? what kind of tank should i use? I don't have access too an aluminum welder -.-', I'm also planning too fill in the gap between the headlights and first bar.
You're doing this with a crappy little Canadian Tire welder? I gotta get me one of those next time they are on sale! Or maybe the equivalent at Princess Auto.
Nice work - A couple of days with the grinder and it will look factory!
Grinder?? Ain't nobody got time for that! A little body filler over the welds does wonders
HA HA! You've been watching to many episodes of "Car Warriors" Body filler is Nue Skule, Old School is weld high, grind down smooooooth, lead floated in if you need to, high-build primer and sand that down, then paint!
