Old Aug 10, 2015, 07:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
need to replace my front wheel hubs looking for suggestions
Old Jul 25, 2013 | 10:52 PM
Anthony Grego's Avatar
Anthony Grego
Default need to replace my front wheel hubs looking for suggestions
so im gonna try to replace my wheel hubs in the fron to see if I cant eliminate the chirping from the wheel wells on turns and slowing down. I already eliminated the brakes and joints.
any suggestions as to brands
are there any greaseable hubs out there.
tips tricks or pertinent info to know before doing the work?
oh and how do I know if its 2 wheel ABS or 4 wheel ABS
Old Jul 26, 2013 | 12:31 AM
Neil Hall's Avatar
Neil Hall
for the abs question you'll see a wire goin too the front hub assembly.. this indicates 4wheel abs. I got a chrip in my front suspension, narrowed it down too either lower control arm bushings, or strut mounts..
Old Jul 26, 2013 | 08:14 AM
ABS will have a toothed ring and a sensor at the wheel. I'm not entierly sure you can replace just the bearing or if the entire hub needs to be replaced. You 2 or 4wd?
Old Jul 26, 2013 | 05:36 PM
Anthony Grego
4WD, I don't remember seeing any wire back there but Ill pull the tire off soon to check once Iv got funds to buy parts
Old Jul 26, 2013 | 06:35 PM
Reject's Avatar
Reject
You can replace the bearing, but the whole thing is easier apparently by alot.
I replaced my Passenger side wheel hub not to long ago, Only problem I had was getting the Hub out/off the Knuckle. I had to removed the knuckle off the truck (which i was trying to avoid) then lay it on the ground and pound it with a 20lb hammer. (I had the HUB on the ground, so It would break/bend the knuckle since it is $600+ to replace (from the dealer) After only a few hits I could see the Hub moving, I also snapped all 3 of the bolts heads off.
Old Jul 27, 2013 | 11:33 AM
kenttt's Avatar
kenttt
Are those bolts dealer only? Or can you get grade 8 (or metric euivalent) to fit from your local friendly bolt supply house?
Anyone have the dimensions of these bolts?
Old Jul 28, 2013 | 01:54 PM
Reject's Avatar
Reject
I got them from the dealer, for like $5 each. No other place had them, and I didnt have time to look, or one intact to measure lol
Old Jul 30, 2013 | 06:06 PM
sawfish's Avatar
sawfish
From what I have read, all of the 4WD Dakotas come with 2 wheel ABS (rear) standard. If you wanted 4 wheel ABS, it was a $495 option in 2005 to add the front wheels, according to the factory invoice for my truck. From that, it looks like if you have sensor wires to the front two wheels, then you have 4 wheel ABS. FYI, the bearing hub assembly runs approximately $70+per each online. My friendly NAPA store quoted me $134.95 each to order them! Found a set on warehouse closeout for $70 total. Still waiting on them to arrive.
Old Jul 30, 2013 | 10:00 PM
Anthony Grego
sawfish u found them where for 70?
Old Jul 31, 2013 | 10:30 AM
kenttt's Avatar
kenttt
Rockauto.com list them online at 33.79 each. (Quality = ?.)
