2009 Dakota, DTCs
Old Aug 13, 2013 | 09:43 PM
Sydeshow's Avatar
Sydeshow
Default 2009 Dakota, DTCs
Hey guys, pulled a couple codes off my dakota today.
It has the 4.7L 4x4 SXT has 42000 kilometers
P0031 - oxygen sensor Bank 1 Sensor 1 Heater Circuit Low
P0032 - oxygen sensor Bank 1 Sensor 1 Heater Circuit High
P0300 - Multiple Cylinder Misfire
P0401 - EGR System Performance
P0500 - Unregistered Code (no description)
Was wondering does the EGR code mean that the valve is finished? not working properly? The light comes on stays on for a few days, then shuts off for a day, then comes on again at some point.
What does the O2 sensor mean? not exactly sure myself.
Anyone know about p0500?
Multiple misfire? is that something i should be worried about?
also one more thing, im looking to put new plugs and wires (or coil over packs?) what would you guys recommend?
Old Aug 13, 2013 | 09:57 PM
How long has the light been on? Is the truck running badly?
Old Aug 13, 2013 | 10:03 PM
Sydeshow's Avatar
Sydeshow
a week or so, and no real performance issues yet that I find. The truck seems to bog down sometimes when i try to go up my drive way or at a light. But it did this before the light came on.
Old Aug 13, 2013 | 10:08 PM
This may sound strange, hows your battery? How's the connections? Grounds? Weak batteries/bad grounds cause all kinds of weird issues with these trucks. If those are ok, try this, disconnect the battery for about a 1/2 hour and then drive it and see if the codes come back. Having all those codes at once is rare. If you had a misfire, you would feel it missing, gas mileage would suck, etc.
Old Aug 14, 2013 | 08:49 AM
Sydeshow's Avatar
Sydeshow
I am sorry i didnt explain that the egr code was what threw the light. the other codes were stored in the computer i found when i did a full system scan.
Old Aug 14, 2013 | 10:23 AM
Ahh, I see. In that case the EGR is toast. I had the same thing on my Camaro. Code was for EGR fault and would come and go at random. I tried removing and cleaning the EGR valve but that did not work. Ended up replacing the valve and solenoid and the code never came back.
I would start by inspecting the EGR system. Make sure no vacuum leaks to the solenoid. Or remove and inspect it, clean it and make sure it operates smoothly.
