throttle cable tension
Old Aug 15, 2013 | 01:50 AM
Neil Hall's Avatar
Neil Hall
Default throttle cable tension
how do you adjust the tension/play on the throttle cable? I have a little more slack than necessary that I would like too get rid of.
Old Aug 15, 2013 | 05:11 PM
superdak05's Avatar
superdak05
we don't have throttle cables, its a fly by wire system, all electronics,
Old Aug 15, 2013 | 05:13 PM
superdak05's Avatar
superdak05
The transmission throttle valve is operated by the valve body throttle lever. The throttle lever is actuated by a cable connected to the engine throttle body lever
Old Aug 15, 2013 | 05:28 PM
FrenicX's Avatar
FrenicX
That's not true? I have a very intimate relationship with my throttle cable. Straight from my pedals swing arm, through the firewall, to my throttle body. And a matching cable from the cruise control servo. I had the fab a bracket for it myself, cruise control is still dangling though.
I'll have to have a looksee if there was a way to tighten it up on my old throttlebody and intake manifold, but I don't think there was a factory way, might have to jimmy rig it...
or use the trick we all used on our rangers on the ranger forums. Stack zip ties around the cable as spacers, in the cab at the pedal.
Old Aug 15, 2013 | 05:41 PM
FrenicX's Avatar
FrenicX
Also, if you look at the pedal assembly, there's part of it that contacts the firewall liner, rubber layer. I trimmed that a bit so the pedal would land on the bumpstop like it's supposed to.
Old Aug 15, 2013 | 10:00 PM
Neil Hall's Avatar
Neil Hall
Thanks FrenicX I will see what I can do tomorrow.
Old Aug 17, 2013 | 06:16 PM
ouv's Avatar
ouv
Yeah, mine is really loose. I bet it'll consist of mini washers or a rubber spacer
