06 dakota transfercase temp
Old Sep 28, 2013 | 10:35 PM
06firedak's Avatar
06firedak
Default 06 dakota transfercase temp
please help!!!! I crawled under my dak to check u joints(which were fine) and noticed my transfercase was very hot to the touch. upon further inspection, I noticed the front driveshaft was also very hot as well as the front diff. the front axles were not hot just the diff. the rear driveshaft was not hot either just t-case, front driveshaft and front diff. I was not using 4x4 so it should not be due to use. I checked t-case fluid level and it was good. checked front diff fluid level and it was good also. also checked transmission fluid and it was also good. transmission felt warm to the touch but not as hot as the others. I have also been getting random transmission temp light. don't believe this would be related but not sure. any input will be greatly appreciated.
