TIP: always double check ujoints before install to save headache
Old Oct 20, 2013 | 06:50 PM
Jeremysp1993's Avatar
Jeremysp1993
Default TIP: always double check ujoints before install to save headache
I bought a Precision 369 ujoint for my front driveshaft. I tried installing it, but it didn't wanna seat all the way. Not sure what was going on. So I tried it in different configurations and it wouldn't seat all the way to put the clip on it. It was like less than 1mm from seating. I tried it multiple times, and no, the needle bearings never once got in the bottom of The cap. I took my caliper to it With the caps on, and one side was .05 inches longer than the other side. And the shorter side was the side that never had a problem. I took it back to oreillys and exchanged it for a new one. I then measured it and the two sides from end to end and it was the same. That one installed easily. IF I measured it in the first place, I would've known. So always double check!
Old Oct 20, 2013 | 07:06 PM
Tom A's Avatar
Tom A
Section Moderator
Wow, .050" is WAY off. No wonder it wouldn't fit. Personally, I try to use only Spicer u-joints, but I have used Precision before with no problems. I'll be sure to double-check them from now on. Thanks for the tip.
Old Oct 20, 2013 | 07:12 PM
Jeremysp1993
Like the caps were fit perfect in the whole, but they wouldn't sink down enough to put the clips on. SO yeah, I'm glad I figured it out. You don't know how frustrated I was!
Old Oct 20, 2013 | 08:01 PM
moe7404's Avatar
moe7404
WOW a lesser mech might not have found that. many years ago my dad showed how to do U-Joints. iam glad i dont have to do them any more. glad yours came out good.
Old Oct 21, 2013 | 07:26 AM
northgator8's Avatar
northgator8
What's a caliper . . . .LOL
I would never have figured that out! I would just assume I was doing something wrong and probably get out the BFH and make it fit.
