Transmission Question
Old Oct 5, 2005 | 10:02 PM
Dak_in_Black's Avatar
Dak_in_Black
Default Transmission Question
Ok, dumb question.
According to the Vehicle Summary Report from a local dealer (thanks for the info draftingmonkey), I have a 5-spd transmission.
However, when I look at the dash I see 1, 2, D, and Tow/Haul. Unless I am missing something that is four, not five.
I haven't had an automatic transmission in a vehicle since 1990, are they counting reverse as a gear? I thought a 5-spd meant 5 *forward* gears.
Old Oct 6, 2005 | 06:23 PM
cvc944's Avatar
cvc944
Default RE: Transmission Question
Reverse doesn't count. There are 5 forward gears, but only 3 of them are selectable, that's why you only see three on the selector.
Old Oct 6, 2005 | 06:44 PM
Dak_in_Black
Thanks for the reply.
I guess that helps clarify it a little. So let me get this straight, "D" is actually 3, 4 and 5 (OD)? So if you select Tow/Haul you are turning "off" the ability of the computer to select the OD?
Am I close?
Old Oct 7, 2005 | 01:59 PM
cvc944's Avatar
cvc944
Correct. The tow/haul button is just grabbing a lower gear electronically, presumably 4th.
