2011 Dakota headlights fogging up
Old Dec 16, 2013 | 10:15 PM
derrick gil's Avatar
derrick gil
Default 2011 Dakota headlights fogging up
The headlights on my 2011 Dakota look brand new, but they keep fogging up. Is there anything I can do to fix them? Any help is much appreciated.
Old Dec 17, 2013 | 12:23 AM
daksnbeers's Avatar
daksnbeers
If your fog lights are fogging up condensation is getting in them. My brothers neon has a crack right on the lenses and does this. You said yours look new but there could be a crack somewhere on the housing instead of the lens. Id pull it out and check.
Old Dec 17, 2013 | 07:37 PM
jasonw's Avatar
jasonw
Site Moderator
+1. Has to be getting in there somehow, crack or damage to the lenses is most likely culprit if the bulbs are screwed in tightly.
Old Dec 22, 2013 | 11:21 AM
kenttt's Avatar
kenttt
If the unit doesn't appear to have any defects in it, drill a 1/8" hole in the lowest point of the bottom, NOT THE FRONT. If you're worried about anything getting in the hole, drill it at a slight angle leaning back at the bottom.
The hole will allow it to breathe.
