Just got EBC pads and rotors
Old Dec 26, 2013 | 06:26 PM
sawfish's Avatar
sawfish
New EBC pads are coated with a mild abrasive that in effect laps the face of the rotor for improved pad to rotor contact. EBC makes a number of different pads for different purposes. There are TWO green pad types. One is heavier duty for truck use. There are also heavier grade pad compositions in different colors for their suited task. A trip to the EBC website is a good idea.
TIP: check your hubs and bearings to be sure they are not worn. Oscillation of the rotor from a bad hub/bearing will rapidly accelerate wear on rotors and pads.
Old Dec 27, 2013 | 08:43 AM
rookie's Avatar
rookie
Great minds, right?
Old Dec 30, 2013 | 03:48 PM
rookie's Avatar
rookie
There was supposed to be a picture of my brakes here too. I got the same ones. when I upload pics it removes the previous one that I posted.
Old Dec 30, 2013 | 09:29 PM
Tom A's Avatar
Tom A
Section Moderator
I put drilled and slotted rotors on the front of mine with EBC Yellow Stuff pads and it made a HUGE difference! I wouldn't have believed that so much improvement was possible from a simple pad and rotor change.
The Yellow Stuff is NOT a low-dust compound, though. My wheels get pretty dirty.
