4WD dry pavement usage question
Old Jan 2, 2014 | 08:41 PM
Deadsquiggles's Avatar
Deadsquiggles
Default 4WD dry pavement usage question
I've noticed this in a couple recent threads now that winter is here, and so I was wondering, what is it about using 4WD on dry pavement that can supposedly destroy your transfer case? And I do know about the binding caused by making a tight turn on dry pavement in 4WD but a few people have said normal driving on dry pavement can cause problems too.
Thanks in advance,
Tommy
Old Jan 2, 2014 | 10:19 PM
dakotaff's Avatar
dakotaff
http://www.4x4abc.com/4WD101/def_turnpart.html
http://www.rubicon-trail.com/4WD101/driveline-bind.html
And so much more information out there...Google is your friend here.
Not sure why you think all four wheels turning at the same pace would be good on dry pavement.
Something has to give, you'll find your weak link...
Old Jan 3, 2014 | 10:52 AM
DakotaJedi's Avatar
DakotaJedi
That second link... Ouch.
Old Jan 3, 2014 | 11:59 AM
Jaded's Avatar
Jaded
I've never owned or needed a 4wd, but still knew this. Seems like the few 4wd's I've rode in had a warning sticker about this near the engagement lever.
Old Jan 4, 2014 | 01:15 PM
jasonw's Avatar
jasonw
Site Moderator
They used to have these stickers more often, next to the engagement lever. Now that most 4X4 systems have gone to ***** (electronic) or buttons, the warning is actually just in the owner's manual.
Old Jan 6, 2014 | 01:39 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I cried a little bit with that second one!
Old Jan 6, 2014 | 01:55 PM
cheeseburger's Avatar
cheeseburger
My Sisters F250 King Ranch had the T-Case Crack just like an egg. running 85 across Laramie WY with the hubs locked and pulling an empty livestock trailer will do that you know.
