Truck pulls left or right or not at all.
Old Jan 12, 2014 | 11:14 AM
Zombifyd's Avatar
Zombifyd
Default Truck pulls left or right or not at all.
Hello again, my truck has always pulled to the right a bit due to an alignment issue. Now for the last couple of days my car will sometimes decide to veer tovtge left and when I brake it pulls harder to the left or right and sometimes it just slows down to a stop going straight like nothings wrong. I will check the front brakes but they aren't even a year old and I'm replacing the back drums and shoes because I hear them grinding as of a few days ago. I just wanted some input on what the veering left and right would be. I have hit some nasty potholes due to the last blizzard and plows creating them.
Thanks for any info!
Old Jan 12, 2014 | 05:06 PM
projektdirtfab's Avatar
projektdirtfab
Something unpredictable and inconsistent like that is usualy worn out steering components and or suspension bushings. Causing the truck to be in a good alignmentone second and pulling the next.
Old Jan 12, 2014 | 05:40 PM
Tom A's Avatar
Tom A
Section Moderator
A rear brake problem can cause a pull to one side, though it usually isn't as strong as a front brake pull. In any case, if you hear grinding from the rear brakes, get them checked ASAP!
Old Jan 12, 2014 | 05:42 PM
Zombifyd's Avatar
Zombifyd
I figured it would be something like that. That reminds me there is like a half inch of play in the steering wheel before the tires react. Just another thing to add to the many things I have to look at. Thank you.
Old Jan 12, 2014 | 05:44 PM
Zombifyd's Avatar
Zombifyd
Yeah I have the drums and shoes at work waiting for the lift to be cleared up. There's a ram with a broken shifter cable that's up there now.
Old Jan 13, 2014 | 08:12 AM
Check your tire pressures too.
