multiple misfire p0300
i have a 2006 dodge dakota 4x4 3.7 . i have change all coil packs and spark plugs , flushed fuel injectors and bank 1 downstream o2 sensor and air intake sensor , still getting mutiple misfire code and some hesitation , check engine light only comes on and flashes when vehicle is first started , anybody got a clue
Welcome to DF. How many miles on the truck? How long has this been going on?
A code P0300 may mean that one or more of the following has happened:
- Faulty spark plugs or wires
- Faulty coil (pack)
- Faulty oxygen sensor(s)
- Faulty fuel injector(s)
- Burned exhaust valve
- Faulty catalytic converter(s)
- Stuck/blocked/leaking EGR valve / passages
- Faulty camshaft position sensor
- Defective computer
When did this start happening? Not to be there bearer of bad news, but wasn't there some valve issues with the 3.7 that resulted in this? Try to get a compression test done. You can do it yourself too, just rent or buy a gauge. This will rule out the valves.
I just bought an 2008 V6 3.7 2 months ago, put 3,000 miles on it and flipped a po300 two weeks ago. reset it and thru it again 5 days later. first put a bottle of fuel injector cleaner in, that didn't work, so we replaced the coil and spark plugs on cylinder #6. I think this is an on going issue..looked at carfax and the service records for the year are lengthy. had a 02 Dakota, v8 4.7 and never had a problem...what gives with this engine?
well, crap...
I logged in to see if I could find anything about the coil packs, and which to get, and from where, but this thread made me dig a bit deeper, found this:
http://www.brakeandfrontend.com/Arti...e_at_idle.aspx
I'm going to move my #6 coil (where my misfire is) somewhere else and then watch it...but.....damn...
Trending Topics
Not to drag a thread from the dead, but my truck just started to have this issue.
The shop had it yesterday and today, and couldnt find anything right away.
Replaced bad O2, Checked Ignition, Fuel, EGR, Cat, nothin obvious has stuck out to them.
Codes:
P0300
P0137
P0158
He did say there is a TSB out for a very similar issue, But mine seemed to come on more quickly
Codes:
P0300
P0137
P0158
well since the summer months truck has run great no "check engine " light exceptfor the other morning 1st start up it was 55 outside , check engine light flashed then went off an stayed off and ran fine , why would it just be troublesome in cooler weather ?
