wipers turn on once when starting truck
Old Mar 20, 2014 | 01:07 PM
Jeremysp1993's Avatar
Jeremysp1993
Default wipers turn on once when starting truck
So I have a weird issue. It happens 99% of the times when starting my truck. When I start my truck, the wiper goes across once and then stays down. Why does it do this? It's so annoying....
Old Mar 20, 2014 | 09:31 PM
Waving Hi to you?
Old Mar 21, 2014 | 12:36 AM
Jeremysp1993
LOL its not funny, its annoying....
Old Mar 26, 2014 | 01:31 PM
Jeremysp1993
bump....
Old Mar 26, 2014 | 07:14 PM
CTSNicholas's Avatar
CTSNicholas
I had this issue a couple days back when it was raining. If I turned the wipers off and shut the truck off it would go once when I started it, or actually just gave power with the ignition really.
I decided to cycle them off, on, then off, and then turn off my Dakota. It didn't go back when I started the truck.
I used the wipers quite a bit the next day and had no issues, though I *did* changed wipers the day it was sleeting. Perhaps wiggling the motor as I took old blades off new ones on fixed it instead? I hope it isn't coming back, odd issue indeed.
Old Mar 27, 2014 | 08:58 AM
DodgeCACares's Avatar
DodgeCACares
CTSNicholas,
The windshield wiper module is controlled by the battery currents received by the wiper motor. In some cases, if the wipers are functioning in an erratic fashion, a loose connection or wiring issue may exist.
@Jeremysp1993, I'm sorry to hear about you wiper issue. If the issue occurs on every start-up, a communication issue may be present in the wiper module.
Old Mar 27, 2014 | 08:44 PM
backinadodge's Avatar
backinadodge
Have your alternator tested. Had this issue with the wipers on a Ford awhile back, and it turned out the alternator was on its way out.
