Coil Spring Rate
Does anyone have any information on the coil spring rate and/or design load for any of the 3G Dakotas? I cannot find any information in them at all. Raybestos offers two spring rates (572 and 690) so it might be one of those but I have had not luck finding a definite anywhere.
The only info on the springs that I have is that they are the same brand as the rest of the front end: "Crapco." Sorry about venting on your thread; wish I had some useful info for you. I guess your looking for an improvement?
here in Wichita , KS we have a full service spring shop. you can take a 3/4 ton pick up in with your camper loaded and they will make new springs to put it level. they do big trucks to. they make the springs right there. if you could find one near you they might be able to help.
I think with a little research, know-how and creativity, you could swap in a decent coil-over with somewhat bolt-on adapters. Hopefully gain a slight lift, more travel and a much better ride. They will cost at least twice as much as a replacement strut + all the adaptive hardware + a nitro charge + blood, sweat, and tears. Maybe seasick isn't so bad.
Just send me your lower arms and ill modify them to allow coilovers and then send you some plates to bolt to your upper mounts then drop the cash for some icons or kings or fox or whatever and youll never have to worry about ride quality again lol
Trending Topics
Would this be, perhaps, cutting the bushing out and welding double sheer tabs in place? Because that is exactly what I want to do. What kind of price are we looking at, including the top mounts?
Yes that is what im talking about. Not sure pricing yet. Not much though being as its just a handful of metal and few hours cutting and welding. More if you want me to include coilovers and hardware but I dont mark up parts. Just charge for my precious time
Sorta like the raider that was built for baja
what kinda numbers on that Baja raider? Shock length? wheel travel? That is where I was headed, but the quality of all the other components (ball joints, tie rods, and bushings) made me hold out for your CAs, and tie rod assembly. is that your work? how far did the bottom shock mount get moved to clear the cv?
