Flat Tire Light
Old Apr 10, 2014 | 10:36 PM
Gtt1229's Avatar
Gtt1229
Default Flat Tire Light
My flat tire light went on back in winter, I filled up my pressure per the door jam, filled it up again during spring, still on. I disconnected the battery for a hour or so, nope. My front right brake is cracked I believe, due to the squealing, so can can that be a potential cause?
Old Apr 11, 2014 | 07:54 AM
dakotaff's Avatar
dakotaff
Keep driving the truck for a while, the light may go out eventually. The brakes will not cause a TPMS light to come on. Not sure if the spare tire has a sensor in it, but check the pressure in it. Or maybe one of the tire sensors simply went bad.
Old Apr 11, 2014 | 08:24 AM
northgator8's Avatar
northgator8
Mine has been on all winter - scares the hell out of my wife! My winter rims do not have sensors, so I actually have to CHECK the pressures every couple of weeks.
Old Apr 11, 2014 | 07:13 PM
rookie's Avatar
rookie
wow, I hate that kind of stuff. some times I miss the central locking, but all in all, I love having less stuff to break. long live crank windows!
Old Apr 12, 2014 | 07:24 PM
Gtt1229's Avatar
Gtt1229
What exactly is the sensor? I got new tires, but that was months before.
Old Apr 12, 2014 | 08:45 PM
dakotaff's Avatar
dakotaff
Each tire has a TPMS (Tire Pressure Monitoring System) sensor in it, when a tire goes below 25% of the recommended pressure, it sends a fault and lights up that idiot light on your dashboard.
  • If a sensor is damaged when changing tires, that could cause the sensor to go bad.
  • Also there are TPMS rebuild kits, usually installed when new tires are mounted, so maybe that wasn't done. This can cut the lifespan of the sensor down.
  • Finally there is the battery in the sensor which sends the signal to the receiver in the system. The batteries are supposed to have a life of anywhere from 5 to 12 years, so if a battery dies, you would get a fault light once again.
I am so damn happy that I don't have TPMS in my truck, or in my car.
Old Apr 15, 2014 | 09:43 PM
Gtt1229's Avatar
Gtt1229
Oh that may explain it, I have had a few flats because these darn roofers left many of the roofing staples laying around have 2 plugs in one of my tires, could of through it off changing them so frequently. Thanks some much everyone!
