Changed water pump, now problems
Old Jul 18, 2014 | 11:47 AM
Jaded's Avatar
Jaded
Default Changed water pump, now problems
I changed my water pump, T-stat, and serp belt, no failure just PM. I just kinda "winged" it since I've done my share of water pumps over the years. In fact, this was the easiest one I've done, once I figured out the fan clutch had right hand threads.
Anyway, since then It's been stalling intermittently when I come to a stop. We're talking out of 10 stops, it stalls once. I have double checked everything I did, no leaks, never any overheating. Have put about 150 miles on it since and has happened 4 times.
The only thing that comes to mind is a good bit of coolant came out when I pulled the old water pump. The radiator was drained, I guess just some excess in the block. I don't see anything electrical that could have got wet though.
Any ideas?
Old Jul 18, 2014 | 12:29 PM
sebeau's Avatar
sebeau
Maybe the IAC, because it work with coolant too.
Old Jul 18, 2014 | 09:29 PM
Jaded's Avatar
Jaded
Thats a possibility. It seems like the idle just falls out. The tach will be at 700, blip down to 500, then 700, then 500 and stall.
Old Jul 20, 2014 | 10:23 PM
keeks's Avatar
keeks
New Member
is your belt routed the right way the pump might be turning the wrong way
Old Jul 21, 2014 | 12:02 PM
The throttle body does not have coolant running through it. Some vehicles yes, not the Dakota, at least my 05 did not. But I would still check out the IAC, maybe just a coincidence.
Old Jul 21, 2014 | 02:12 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Correct, our trucks do not have coolant running to the IAC. I would not say that the coolant system is directly responsible for your target idle. However, the ECU uses perceived coolant temp as part of the fuel and ignition delivery....which is what it sounds like you are having.
Old Jul 21, 2014 | 07:56 PM
Jaded's Avatar
Jaded
Thanks guys, appreciate all the help. Funny thing is since I posted this thread it hasn't done it again (knock on wood). One thing of notice is my temp needle is riding slightly higher than before. I did go with the stock(195) stat, so not sure why it's higher. The idle seems to be slightly lower than before also.
donkeypunch, what you're saying makes sense. wonder if my new t-stat is causing problems? or maybe the ecu just needs to learn to live with this higher temp?
Old Jul 24, 2014 | 07:58 PM
Alfons's Avatar
Alfons
Low idle rpm and occasional stall shouldn't have much to do with the work you did, but it could relate to a very wide gap in the plugs. It doesn't take much to check this and it does happen over time - the high energy going through the plugs will burn away quite a gap before you'll notice it (usually with occasional stalling).
Old Jul 26, 2014 | 08:57 PM
Jaded's Avatar
Jaded
Plugs are copper with 18,000 miles on them, they should still be good. Temp needle is now riding in the proper spot, have went 300+ miles without a stall now.
Old Jul 27, 2014 | 08:28 PM
Alfons's Avatar
Alfons
18000 miles can be a lot for a set of copper plugs and instead of guessing, it doesn't take that much time to have a look
