Passenger Air bag issue
Old Aug 5, 2014 | 04:20 PM
bchapin05's Avatar
bchapin05
Default Passenger Air bag issue
Anyone ever had issue with the airbag light coming on randomly? After driving about 10 minutes or so my airbag light will come on as well as the airbag off sign and then it makes a ding noise. I have the airbag turned on but have turned it off to see if something was wrong with the key switch but it still does it regardless of if its off or on.
Checked both airbag fuses and they look fine. Assuming it might be a sensor of some kind? Can O Reilly's or Autozone pull a code on the air bag light?
Old Aug 5, 2014 | 06:20 PM
ErikMissile's Avatar
ErikMissile
I've had my instrument cluster light up randomly for a few seconds or one key cycle. It's always reset itself. I've never had both the dash panel light and the passenger light come on together. I'm not sure if AutoZone can give anything but engine light codes. If it was just your passenger airbag on/off light being strange then the problem could be as simple as junk caught in the belt buckle latch but not sure about the instrument cluster light coming on with it.
Old Aug 5, 2014 | 06:32 PM
dakotaff's Avatar
dakotaff
Take a drive to Autozone or Oreillys and see if they can do it, but I don't think that they can. Sometimes a weak battery will throw an airbag error code, maybe check yours.
Old Aug 7, 2014 | 02:46 PM
bchapin05's Avatar
bchapin05
I figured it out. This is extremely dumb but I noticed if once the light came on I pushed hard on the seat it would go off. So I was assuming it was something with the weight sensor in the seat. Then I realized I had forgot a bottle of vodka in the back from when I went camping. The bottle had wedged under the seat and was pushing into the seat pretty hard. Removed vodka and now its not coming on.
Old Aug 7, 2014 | 04:27 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Removing alcohol always helps (:
Hopefully the calibration isn't off. I doubt it is though.
Old Aug 8, 2014 | 11:51 AM
kenttt's Avatar
kenttt
Vodka will do it to ya every time!
Old Aug 8, 2014 | 12:07 PM
dakotaff's Avatar
dakotaff
Never blame the vodka. Never!!!!!!!!
Vodka is you're friend.
