Air/Fuel Ratio Gauge / Shocks
I have two quesions I need assistane with:
1. I have already purchased the gauge pod that fits directly over the steering column, and I would like to install a voltage gauge as well as air/fuel ration gauge. However I do not know if I need or if it is recommened to purchase a new O2 sensor along with the gauge.
2. I will also be purchasing shocks for my truck, however I have never purchased shocks before and am unaware where to begin. What manufacturer & size is do you all recommended ?
2006, 4X4, 4 door with 2" front spacer and 32" tires
We have struts up front and shocks in the back. There is not a selection of different sizes. Rancho, Monroe, & KYB offer the parts for our trucks, with Rancho & Monroe being the popular choices. Do a search here for plenty of threads on that subject. No idea on the sensor recommendation though.
What information are you expecting to get from an A/F gauge?
X2 on the shocks. Rancho is the stiffest, Monroe next, the KYB is more like OEM (soft). You should also check your other front end parts while your in there.....tie rod ends, sway bar links, ball joints....etc.
As mentioned in an earlier post regarding poor MPG, I want to know if my truck is running rich or lean ... I am determined to improve my mpg !
Thank you all for the advice.
Regarding your question about using your existing sensor or a new one, you first need to know the differences between a narrow-band and wide-band O2 sensor. If you want "general" information about O2 voltage, stick with narrow-band (although if you choose this as your tuning tool, you have zero business trying to do any tuning what-so-ever). So, you would want a wide-band sensor, controller, and gauge. We use Innovate units in the race cars.
