Two problems.
Old Nov 12, 2014 | 07:41 AM
northgator8's Avatar
northgator8
Originally Posted by phil74501
You really want me to go through the list of problems I've had with this thing? Seriously?
3 power steering pumps, 2 water pumps, power steering rack, a broken brake line which dumped all my brake fluid out leaving me with no brakes while going 50mph down a highway, a brake line that leaked, both brake cylinders in the rear leaked, 1 broke once again leaving me with no brakes , that's all 4 brakes going bad if you're keeping count, drive shaft replaced, 2 rear ends, last one didn't last a year, blower motor, 2 blower motor resistors, cd player quit working long ago, ball joints went out before 30K miles, sway bar bracket broke hitting a pot hole at about 35mph, when it rains i get water in the floorboard on the passenger side, the steering wheel has play in it that nobody can figure out why or fix, transmission replaced, radiator replaced, pinion screw in the rear end broke causing the rear end to lock up, the U joint to break, and the drive shaft to fall off, now a new engine. I know there's more things that have gone wrong with it, but I can't remember them all. I'm sure you've gotten the point by now.
Bad apple? Please. Would you buy another Dodge vehicle after what I've been through with this thing? And it STILL has problems with it? Only if you're a fool.
Yikes! Did you buy it new? I really sounds like a flood truck, maybe salt-water.
Old Nov 12, 2014 | 08:29 AM
Guilty. Had plenty of poblems with our 09 Journey. Bought another one in 2013. I'm so foolish.
I am sorry for all your problems, really, but it sounds like that truck was abused, flooded, something. None of that is normal. Let's just say, I don't have alot of sympathy once your to the point of bashing Dodge vehicles on a Dodge forum and name calling. Good luck with whatever you decide.
Old Nov 13, 2014 | 08:30 AM
CanadaDak's Avatar
CanadaDak
The gas tank issue is either a pluged vapor canistor or the vent line for the fuel tank is plugged. Just had this issue for months and dropped the tank replaced the canistor. Mine got water logged loading the boat this summer. It was clearly the issue as the vapor canistor was about 5 pounds heavier than the new one. Solved the problem tho
