EGR code P0406
Old Dec 11, 2014 | 07:42 PM
20Dakota05's Avatar
20Dakota05
Default EGR code P0406
Hey guys,
I'm getting a check engine light recently and it's putting out code P0406 EGR Position Sensor Circuit High. Also accompanying this check engine light is a tick or nocking sound when I start the engine. The sound gets quitter after about 2-3 minutes of driving, then it's hardly noticeable.
Have any of you had this problem and do you think the noise is related to the EGR code?
Old Dec 12, 2014 | 10:46 AM
DodgeCares's Avatar
DodgeCares
Originally Posted by 20Dakota05
Hey guys,
The possible causes for this code are the following:
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO THE (F856) 5-VOLT SUPPLY CIRCUIT
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT OPEN
(K900) SENSOR GROUND CIRCUIT OPEN
EGR SOLENOID ASSEMBLY
PCM
You can contact your servicing dealer for further diagnostics.
Old Dec 12, 2014 | 02:38 PM
dakotaff's Avatar
dakotaff
Replacing the EGR valve will most likely address your issue.
The part is about $30, but it's a bitch to get to it.
The ticking should be something else, maybe nothing at all.
Old Dec 12, 2014 | 11:48 PM
20Dakota05's Avatar
20Dakota05
Ok thanks. Ya from what I read the egr is a pain to replace. But probably better than paying a shop $$$ todo it.
Old Dec 17, 2014 | 10:39 AM
superdak05's Avatar
superdak05
should take you no longer then 20 minutes to change out egr, just get a nice extension for your ratchet and go slow, and angled mirror on the wiper cowl will help you out seeing the 2 bolts that hold it in
Old Dec 21, 2014 | 10:18 PM
20Dakota05's Avatar
20Dakota05
Got it replaced. Took me about 45 mins. Guess I work slow lol. Cleared the code right up. As for the clicking noise, I think it is a exhaust leak at the manifolds.
