winter oil
Old Oct 26, 2005 | 09:33 AM
nytstker's Avatar
nytstker
Default winter oil
I'm using a synthetic oil for my 5.7 hemi. (5w-30) For winter time should I being using a different grade oil for cold weather or remain using the same as i am using now?
[IMG]local://upfiles/17499/8167B18132AA45E9B210D9B98263EAC0.jpg[/IMG]
Old Oct 26, 2005 | 05:44 PM
danpfay99's Avatar
danpfay99
Default RE: winter oil
I've run amsoil 5w/30 in my last three trucks year round without any problems. You should not have any problems
Old Oct 26, 2005 | 06:41 PM
DakotaStone's Avatar
DakotaStone
ORIGINAL: danpfay99
Is amsoil any good? I've been talking to a distributor about it. Not too sure yet.
Old Oct 26, 2005 | 11:39 PM
Disgorilla's Avatar
Disgorilla
Keep it the same...
Old Oct 27, 2005 | 06:00 PM
danpfay99's Avatar
danpfay99
I've been using Amsoil for years , in several different trucks & never had a problem. Just my thoughts & couple million other peoples also.
Old Oct 27, 2005 | 10:47 PM
DakotaStone
Are you using the synthetic? If so, is there a power gain difference?
Old Oct 27, 2005 | 11:00 PM
nytstker's Avatar
nytstker
I feel a difference in performance but not a difference in the gas mileage difference
Old Oct 27, 2005 | 11:10 PM
danpfay99's Avatar
danpfay99
I'm running it in the engine & front & rear diffs right now. the engine temp is a little cooler & the rpms dropped about 100 rpm to drive the same speed. later this year I plan to change the tran. fluid & transf. case. They claim that if you go all syn. fluids that you will gain 1 to 1.5 mpg. Plus the Aero turbine muffler I'll be truck driving w/ car mileage hopefully.
Old Oct 27, 2005 | 11:15 PM
nytstker's Avatar
nytstker
will the warrantee be void if I change the front and rear differentials fluids to synthetic?
Old Oct 27, 2005 | 11:24 PM
danpfay99's Avatar
danpfay99
No it will not amsoil meet or exceeds all factory specs. + they stand behind their product 100% if something goes wrong & its their products fault they will fix it. ( gotta quit now starting to sound like a salesman.)
