Loose drivers window when rolled down.
Old Jan 11, 2015 | 07:08 PM
ForkliftJeff's Avatar
ForkliftJeff
Default Loose drivers window when rolled down.
Curious if this has happened to anyone else or if you know how to fix it. When my window is rolled down or even half down it rattles around quite a bit when going over bumps and especially when closing the door. I can grab the top of the window and move it side to side (left to right). Perhaps just a loose bolt inside the door or a broken part? Any help or pictures would be great.
edit: It is a quad cab with power windows.
Old Jan 12, 2015 | 02:51 PM
Blue 05 Dakota's Avatar
Blue 05 Dakota
The "fuzzy" channel that the window rides in (at rear edge) has probably fallen down into the door. This happened on two of my doors.
I just removed the door panel, found the channel in the bottom of the door, and glued (RTV) it back into place. Haven't had any trouble since.
Old Jan 12, 2015 | 05:43 PM
ForkliftJeff
Cool thanks for the tip. I'll check it out when the weather gets a little warmer.
Old Jan 16, 2015 | 05:06 PM
Reject's Avatar
Reject
That is exactly what it is, I had it happen in mine, same symptoms. the strip slide down and fell off.
