Thinking of Buying An 06 Dakota Quad Cab 2wd......
Old Jan 16, 2015 | 10:20 PM
LzeroKI's Avatar
LzeroKI
Default Thinking of Buying An 06 Dakota Quad Cab 2wd......
Hey guys,
I'm brand new to the forum. I'm looking to buy my first truck, mostly as a daily driver.
I've found a couple 2006 Dakota Quad Cab V8's with 2wd that I am looking at. Both are asking about $10800, with about 90k miles.
Is there anything in particular I should be scared about as far as this model of Dakota goes? I've heard they had some problems with bad vibration, is that true?
Thanks for any help you guys can provide!!
Old Jan 17, 2015 | 08:20 AM
Search the site. Front end problems. IMO that's too much for a almost 10 year old truck with close to 100000 miles.
Old Jan 17, 2015 | 08:46 AM
adamjeeps's Avatar
adamjeeps
My 05 with 35,000 miles had the sway bar end links shot. Tire shop replaced them when I put new tires on. I should have just told them to take off the sway bar, lol.
Old Jan 17, 2015 | 08:55 AM
adamjeeps's Avatar
adamjeeps
I'd also check the cab for water leaks.
Old Jan 17, 2015 | 03:20 PM
h2ogunr's Avatar
h2ogunr
no dont do it you will be sorry-money pits
Old Jan 17, 2015 | 07:50 PM
This is a biased, incorrect and ignorant statement. All vehicles have problems. If maintained properly, 3rd gen Daks are very dependable and capable trucks. Sure, there are a few Monday trucks in the mix, but that is true for any vehicle.
Old Jan 18, 2015 | 04:08 PM
dsimm87's Avatar
dsimm87
Let me first state that I love my '07. Secondly, (as mentioned above) check that front end suspension, specifically the struts. When you'e doing the test drive, see how much it bounces around, especially at highway speeds or over speed bumps. Not a deal breaker, but if they're bad, get them to knock the price down so you can replace them.
Thirdly, I'd look into an '08+ model year v8. More horses and torque stock. Shouldn't be that much of a price difference either between the 05-07 and the 08+.
Good luck, if you buy one, post a pic!
Old Jan 18, 2015 | 06:26 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
As if any car was ever an investment.
Old Jan 26, 2015 | 10:32 PM
jnd03's Avatar
jnd03
if you are interested i got an 05 4x4 quad cab with 58k miles ill sell you for $9500.
http://i26.photobucket.com/albums/c1...409_190739.jpg
Old Feb 4, 2015 | 07:02 PM
stonny9's Avatar
stonny9
In south Fl August 2014 I bought an 05 Quad Cab 2wd hard tonneau cover, radio, and 80% tires with 84k miles. Private party wanted $9,999. Was throwing code for trans solenoid and staying in 2-3 till restart and a search said solenoid was most likely the problem. Seller settled on $9,200 as I told him it would cost about $700 to fix at shop. I fixed myself for $300 part plus I wanted to change all fluids anyways.
I searched cl for 8 months and it was an ok deal but now I consider it a great deal. Tonneau cover is worth its weight in gold, truck actually has a full $1000+ system, and 2"-4" lift. Turns out my brothers coworker traded it in 8 month prior if I haad heard about it I could have saved another $1000+ via a direct purchase. I needed the truck as I waited to purchase till my car was sold.
