Rancho RS5757
Old Feb 4, 2015 | 02:00 PM
.:Chainman:.'s Avatar
.:Chainman:.
Default Rancho RS5757
So I was driving down the road at a decent 55 when I hit a rather large hump in the road, at an intersection, launching my truck. All tires came off the street and I landed pretty hard on the front end. now both struts are leaking. The truck shut off, which I just restarted no problem. My question is, are these still the only decent struts for our trucks?
2005 Dodge Dakota
4X4 3.7L
Old Feb 4, 2015 | 03:03 PM
Rancho, KYB or Monroe. Rancho will be the stiffer of the two followed by Monroe. KYB is closest to stock. I ran Monroe. Loved them. Others, Rancho and they love them.
Old Feb 4, 2015 | 04:37 PM
.:Chainman:.
The ones on it now are the Rancho's. They have about 60000 miles on them. I haven't beat them that much but I don't baby it off road either. I was hoping someone else had made a stiffer strut than Rancho. They're fine but just not stiff enough for my liking.
Old Feb 4, 2015 | 05:14 PM
dakotaff's Avatar
dakotaff
Ranchos are the best for the jumps.
Old Feb 5, 2015 | 12:24 PM
rodslinger's Avatar
rodslinger
You can check on the RS5829. This is the model used on the 2010/2011 Dakota. As far as I have found the dimensions and mounting are identical. Body, compressed and stroke length are the same also. It appears to only be a valving difference as even the OEM top mounts are the same. Just not sure if it is softer or firmer than the 5757. Maybe Rancho can give you the info. I have these on mine and they are WAY firmer than stock.
