Trans coler line
Old Mar 22, 2015 | 12:25 AM
archemedes74's Avatar
archemedes74
Default Trans coler line
on my '05 I have a small leak (enough to annoy me when crawling under truck) at the radiator, is trans fluid and coming from passenger side line. Is there supposed to be any seal in there? It's not bad, just a little wet, but trans fluid isn't cheap so I'd rather fix a leak than add fluid
Old Mar 22, 2015 | 09:32 AM
Is it coming out of the actual radiator connection or the part where the rubber is crimped on the end fitting? That's a common leak point in these trucks.
Old Mar 22, 2015 | 04:26 PM
archemedes74
where it goes in the radiator
