would like more power
Old Aug 2, 2015 | 11:42 AM
kota17's Avatar
kota17
New Member
Originally Posted by i.who.made.you
Rockauto sells reman HO cams for the J VIN 4.7L. Factorychryslerparts does too. Both will run you over $1000 for the CAMS and if you don't install them yourself it's not cheap. I really want a set but realistically you would be better off installing a NOS wet kit that's only a 75 shot or even a 50 shot designed for 4&6 CYL engines. I know a lot of people don't like NOS but a set of HO cams won't net you but 30 ponies and a mild NOS kit doesn't pose much of a threat to the engine and would allow you to maintain good mileage around town while delivering the extra power in front of the sled. Hundreds of dollars cheaper too.
your not allowed to run nos or even have the kit setup on your truck while pulling.. there very strict about that, its a huge safety issue
Old Aug 2, 2015 | 07:57 PM
kota17's Avatar
kota17
New Member
has anyone done the electric fan upgrade? and if you have did you go with a 16 or 17 inch single fan or 10 inch duels?
Old Aug 3, 2015 | 06:27 PM
northgator8's Avatar
northgator8
Please use search! There is a whole thread on finding an original Taurus fan, a Volvo two-speed relay, and a BMW two-temp thermostat. All parts can be found at the junk yard, except the original Taurus fan is hard to find.
Old Aug 4, 2015 | 11:23 AM
kota17's Avatar
kota17
New Member
i try to use the search but it never works properly for me
Old Aug 4, 2015 | 12:26 PM
dakotaff's Avatar
dakotaff
1-- Here ya go, there's a few additional links in the thread too.
2-- E-Fan write up
