Another round of "What sound is this?"
Old Aug 3, 2015 | 04:15 PM
xNeed6SpeedX's Avatar
xNeed6SpeedX
Default Another round of "What sound is this?"
Ahoy hoy everyone,
So had new clutch kit put in and throwout bearing replaced about a month ago. As of this past heat wave have noticed when the engine is warm and when i depress the clutch i get a creaking noise like an old door hinge. This noise occurs only when the engine is warm and will happen if the engine is off but again only when warm. Also when depressing the clutch in neutral (maybe also when in gear but cant hear over engine) when the engine is running i will get what feels and sounds like a bad throw out bearing with the exception that it is only when a certain amount of pressure is applied on the clutch and that it sounds more like that of metal or tin cans? Not very loud but these noises are nothing I want to be hearing after just having dropped $1000 into the clutch. BTW place that did the work is going to take a look at it Thurs. Thx ~
