2006 dodge dakota P0452 code
Old Sep 17, 2015 | 10:38 AM
jamesheds's Avatar
jamesheds
Default 2006 dodge dakota P0452 code
I have a p0452 code on a*2006*dodge*dakota extended cab. I was told to try to replace the purge solenoid and Leak detection pump and then reset the code. Anyone know if that sounds right or would you go about it a different way? Thanks
Old Sep 21, 2015 | 08:16 AM
dakotaff's Avatar
dakotaff
The small leak is harder to find than a large leak. You can throw parts at it, or live with it until it turns into a large leak. This code can be a bitch sometimes, the cause could be as simple as a cracked hose.
https://dodgeforum.com/forum/3rd-gen...0452-code.html
Old Sep 21, 2015 | 09:34 PM
Jaded's Avatar
Jaded
I think the leak detection pump and solenoid are the same item. So, I'd agree with the advice given.
