360 Magnum Swap
Old Nov 11, 2015 | 06:07 PM
HunterBee's Avatar
HunterBee
Default 360 Magnum Swap
thinking about doing a 360 magnum swap, but I have no clue where to begin, other than the engine. any tips of ideas? from engine to transmission to exhaust ?
Old Nov 12, 2015 | 07:55 AM
What year is the 360 from? Hope your pockets are deep. You will need pretty much everything. Engine, transmission, transfer case (if 4x4), drive shafts, PCM, wiring harnesses, probably the instrument cluster, custom engine mounts, possible frame modification for the engine cradle, front suspension issues, etc, etc. Might be easier to graft a Dakota body on a Ram or 2nd gen Dakota frame.
Old Nov 12, 2015 | 10:45 AM
HunterBee's Avatar
HunterBee
just an estimate, for the cost of the entirety of the parts, how much do you think it'd cost? I have the tools and time to take care of it so no mechanics necessary !! it's either the 360 magnum or an LS3, maybe an LS1 for the swap. as for the model of the 360, I wasn't exactly sure which year to go with.
Old Nov 12, 2015 | 11:02 AM
I have no idea. Start calling around and checking. You need to stick with 96 or newer to be OBD2 compliant unless this is an offroad truck only.
Old Nov 20, 2015 | 03:54 PM
rookie's Avatar
rookie
i think the chevy engine would provide better value, and you have to change all the same stuff anyway, plus the chevy has more available for it. I think I would go with a hemi, though. Its been done, and it can be tuned to use the existing harness and ecm. Only one frame mount has to be altered. I believe the oil pan has to be modded to fit. Search the hemi dakota project.
Old Nov 21, 2015 | 08:09 AM
93 ragtop's Avatar
93 ragtop
You may find this site interesting!! http://lsdak.com/
