snapped 4wd spindle
Old Feb 1, 2016 | 08:04 AM
Anthony Grego's Avatar
Anthony Grego
Default snapped 4wd spindle
soooo was doing a little light offroading n hit a dip a bit too hard. ended up snapping the spindle that the driver side cv axle attaches to on the front differential... snapped clean at the case to the diff, luckly didnt bust the seal, she kept all her oil inside. anyone ever work on these before or have any idea how much of a pain in the *** its gonna be to fix... im seriously thinking about a solid axle swap if i keep busting front end parts even doing light offroading.
picture to come after i come home from work
Old Feb 1, 2016 | 08:21 AM
Replacing a spindle is a cake walk compared to going SAS on these trucks. Remove the axle nut, pop the ball joints, tie rods and sway bar links off, unbolt it, bolt in a new one. Hardest part is probably breaking all the bolts loose.
Old Feb 2, 2016 | 10:53 PM
Tom A's Avatar
Tom A
Section Moderator
Definitely post a picture. I'm interested to see what you're talking about, since it doesn't seem to be what I call the spindle.
Old Feb 4, 2016 | 10:49 AM
rookie's Avatar
rookie
torque is what breaks axles. do you think maybe the wheels came off the ground? this creates a sudden shock when the spinning wheels make contact with the ground again.
disconcerting that "light" wheeling broke your axle. I know the rest of the front end is weak, but i consider the drivetrain of the dakota relatively stout. are you V8? leveled/lifted? 8.25 front end? big tires? also weird that the stub broke and not the joint.
Old Feb 4, 2016 | 01:09 PM
projektdirtfab's Avatar
projektdirtfab
Case to diff? Doesnt sound like you broke a spindle. Sounds like you snapped the inboard snub on your cv joint?
Either way, pics or it didnt happen! :-P
