Homemade Tools..Anyone Else
Old Mar 13, 2016 | 11:14 AM
travle's Avatar
travle
Default Homemade Tools..Anyone Else
Anyone else make their own tools to do repairs on this truck? I have made a ball joint press, coil spring compressors, and an inner tie rod tool.
BALL JOINT PRESS: FLIP IT AROUND AND IT WILL PRESS THE NEW ONE IN.
<a href="http://s1355.photobucket.com/user/travle7/media/0306161031_zps51gvdf6i.jpg.html" target="_blank"><img src="http://i1355.photobucket.com/albums/q706/travle7/0306161031_zps51gvdf6i.jpg" border="0" alt=" photo 0306161031_zps51gvdf6i.jpg"/></a>
<a href="http://s1355.photobucket.com/user/travle7/media/0306161112_zpsknyyz79d.jpg.html" target="_blank"><img src="http://i1355.photobucket.com/albums/q706/travle7/0306161112_zpsknyyz79d.jpg" border="0" alt=" photo 0306161112_zpsknyyz79d.jpg"/></a>
MY TIE ROD TOOL I MADE TO RESEMBLE THIS ONE ALONG WITH AN INSERT TO MATCH THE FLATS ON THE TIE ROD.
<a href="http://s1355.photobucket.com/user/travle7/media/tierod_zps0kulfuss.jpg.html" target="_blank"><img src="http://i1355.photobucket.com/albums/q706/travle7/tierod_zps0kulfuss.jpg" border="0" alt=" photo tierod_zps0kulfuss.jpg"/></a>
Old Mar 14, 2016 | 02:11 PM
bain64's Avatar
bain64
Nice work on the press. I'd be interested in the spring compressor if you wouldn't mind sharing that tool hack.
Old Mar 16, 2016 | 02:24 PM
travle's Avatar
travle
Each block welded together was a solid block. I drilled a 5/8 hole all the way through on the longer side and the top side i either drilled a 5/8 hole or drilled and tapped it for 5/8. The 5/8 hole on the longer edge i cut it down the center with a band saw. Used an app on my phone to approximate the angle of the coils on the spring and welded the cut off portion at that angle. I used a 5/8 bolt that was 8" long. It works and holds good. I was hammering on the old shock while it was compressed and the compressors i made never slipped.
The diameter of the coil was around 5/8" so that's where that size came from, and I just used a 5/8" socket head cap screw because i knew it was strong enough and I already had the 5/8" drill bit out so no extra drill bit for the bolt clearance hole.
<a href="http://s1355.photobucket.com/user/travle7/media/0316161219_zpsl4oxkdqe.jpg.html" target="_blank"><img src="http://i1355.photobucket.com/albums/q706/travle7/0316161219_zpsl4oxkdqe.jpg" border="0" alt=" photo 0316161219_zpsl4oxkdqe.jpg"/></a>
Old Mar 18, 2016 | 10:30 AM
bain64's Avatar
bain64
Great work, thanks for sharing.
Old Mar 19, 2016 | 12:45 AM
travle's Avatar
travle
Thanks. The ball joint press was suppose to be one piece, but I screwed that up when I decided to change the design, mid way through, to lose some of the weight by making the outside diameter smaller. Forgetting that one end had a bigger inside diameter and bored deeper than the other, I ended up cutting it in half. Got lucky and found the middle section already containing a hole big enough for the shaft of the ball joint, and just decided to weld everything together instead of starting over.
