Truck part unknown.
Old Mar 19, 2016 | 03:03 PM
marriaza40's Avatar
marriaza40
Hello, Yes I can shift out of park without pressing the brake, I turn on the engine and I also can shift to R N D.
Originally Posted by erau
Seeing as it appears pretty solid in nature for whatever operation it does (possibly safety-related), I'm going to guess that it may be a column-shifter interlock.
Are you able to move the shifter out of park without pressing the brake?
Old Mar 19, 2016 | 06:07 PM
erau's Avatar
erau
I think you found your answer.
Old Mar 19, 2016 | 11:19 PM
marriaza40's Avatar
marriaza40
Hi, I connected to the shift stick and pluged to the harness but it didnt work, I verify if the actuator is working well, I connected direct to the battery and it worked well, but when I pluged to the harness it doesnt work, I can still shift from park without pressing the brake.
I am also having check engine light, the code is P700 and P750, the transmission only works in 2nd and 3er, but it shift only with the stick.
Old Mar 19, 2016 | 11:30 PM
Jaded's Avatar
Jaded
Wish I would have thought of removing this. My mother got a newer vehicle 4 years ago and had a hell of a time adjusting to that. All her life of driving she just dropped it into reverse or drive and went on her way.
