Front end ALMOST grinding noise
Old Apr 22, 2016 | 12:57 AM
Dhudie74's Avatar
Dhudie74
Default Front end ALMOST grinding noise
I KNOW. YOURE THINKING "READ THE OTHER 472 THREADS ABOUT THAT!"
I have.
07 Dakota 4x4 there is a sound almost a grinding noise and vibration coming from the front right wheel. Immediately I thought wheel bearing. When I looked I noticed the half shaft had come off the differential output (stub) shaft which seemed to have a slight amount of play. I changed the outer axle bushing in the diff (c205) as well as the seal and the retaining clip for the c/v cup/half shaft. The lube looked ok, the hub assembly has a tiny click when turned but so does the opposite side.
I'm far from inexperienced in the world of mechanics especially four wheel drive, but this has me baffled. Even though I'm confident it's not them. I plan to rotate the tires tonight. I wanted to put a feeler out there and see if there's something Dakotas were prone to which I'm missing though.
Old Apr 22, 2016 | 11:48 AM
Dhudie74's Avatar
Dhudie74
Ok. Rotated tires... No Help. Still have the noise/vibration from front right.
Forgot to mention, lower ball joints, rotors/pads, and tires < six months (12-14k)old.
It's not often I'm completely stumped, but....
[DOES ANYONE HAVE ANY IDEAS!?!???
Old Mar 29, 2019 | 11:49 AM
Terrig's Avatar
Terrig
Was it the bearing assembly?Just curious as I'm about to change mine
